 - 21 May 2007
Thought any random search for "120mm" would bring up 23000 versions of this question, but it would appear not.
My CPU fan is starting to tire, it's a noctura NF or a Yate d12sm if memory serves...in a Tuniqtower.....it's just getting to the point where if the machine is off long enough to get back to ambient temps....the fan has trouble starting....still manages it on it's own without a tap....but wont be long before it gets like my old Athlon cooler that needed to be handcranked like an old aircraft and could resonate itself to a stop at times (usually when I was out which is how I found out just how hard it is to melt an athlonXP2800.)
And runtime cooling looks a little ropey too, though I dare say the heatsink is nearly solid with crap by now, which is probably doing that most bizarre and hateful of PC tricks.....overheating a the fan.
Noise is not an issue there's three PC's in here, and this is for the windows gaming machine which already drowns the others out. All I care about is mucho CFM!!!!
Any thoughts (without getting into anything insanely expensive made for the army or NASA or someone).
And just while we're at it.....what's a good, reasonably blowy but cheap 120mm to buy a shedload of for the 3 aging antec900's? Some of the fans are Juuuussst starting to go wobbly in the oldest machine (over 3 years old, runs linux, only powers down in a powercut, so nothing to whinge about).
Cheers folks...I hope I can get a good answer and get the hell off this website again before the buildbug bites (I'm broke so it would be a frustrated build bug resulting in endless fantasy shopping carts and hatred
 because l think the vipers are not that loud, at 1700rpm l can just here them, the vipers are only 28db Noise (dB[A]) at 2000rpm.
