Spent 4 hours bulding a computer last night to find out its not booting,
basically whats happening is that i turn it on, the LEDs at the front flash and then turn off.
I think it could be a short circuit so i will check the mobo is not touching the case but i did get it working ONCE!!!
turnt it off, put the ram in (was troubleshooting and wondered if it was RAM), then it flashed again... since then its not worked at all, i've tried taking out ram again, tried taking out GPU, playing about with plugs too, here is the spec
AMD Phenom II X4 955 with stock CPU Cooler
XMS3 Corsair RAM , 4 GB
ASUS GTX460 768mb GPU
Zalman Z7 Plus case
Gigabyte 880GM-UD2H Atx mobo
Corsair CX500W PSU
Samsung F3 500gb hdd
Samsung ODD
any suggestions welcome
Thank You,
Jamie.
Zalman Z7 Plus case
Corsair CX500W PSU
Samsung ODD
Thank You,
Jamie.
