OCUK Sandy Bridge, SB-E and Ivy Bridge 5GHZ Club
OP
25 Nov 2002
Somerset
5.3??? Wowser lol
Quick question, is high voltage dangerous refardless of temperature increase? that is, will just the voltage frazzle the chip regardless of cooling? Even if it was theoretically running loaded at 20*c?
Just to put a bit of perspective here...
The guidance about voltages is just that guidance and it was also mentioned when Sandy Bridge had just launched and One chip (mine a 2500K) stopped working properly. We still don't know why it stopped working and probably never will.
As the week has gone on OCUK have stress tested some Sandy Bridge processors at higher voltages and nothing has failed yet.
Of course high voltages are risky, that's why you take it slow and easy, step up very gently and stop when you feel uncomfortable. Running these voltages day in day out would be very likely to cause problems, but for some benchmarking and screen shots to brag about, I think they are fine.
Having said all that i'm quite reluctant to go above 1.45 vcore.
8 Oct 2006
Midlands
I'd have to agree. For the bump up i needed just to get stable long enough to run super pi it just isn't worth it for me. Possibly in the fullness of time someone will find out that setting xyz to 1.523542352v will give you some more headroom.
For the moment though its still all on the vCore and at that, I'm happy at 1.38. At the moment that looks like it might mean a max clock of 4.6 for me at the moment though at 4.7 BSOD 2 hours into Prime.
22 Mar 2009
Think I might be getting a little carried away now....
How gutting to be so close to a sub 7s time :eek:
Your cpu will reduce in lifespan sooner. Cos one day OCUK and myself will going to say "told ya so!".
28 Nov 2009
Manchester
I think intel might have shot themselves in the foot making these chips run so cool- least with hotter ones you know when to stop...with these it seems to bork before the temps get unsustainable!
23 Nov 2002
Near Bristol
Not really, there isn't really a downside to lower heat output on any computer component. The main problem is simply the fact users are so used to clocking 45nm CPUs that many don't seem to realise that using the same sort of voltages on 32nm process CPU is a receipe for disaster.
22 Mar 2009
SimonMaltby cpu could dies anytime sooner or later if he kept pushing more than 1.45vcore as he probably think ocuk will replaced his dead cpu if anything has happen to him.
OP
25 Nov 2002
Somerset
Overclocking is a risk. My first CPU failed, but not because I did any stupid overclocking. This one is being overclocked in a controlled and calculated manor. I would not dream of running these voltages for long and would not dream of returning it for an RMA if if failed and i thought it was because I pushed it too far.
I brought this chip to have fun, and to me fun is benchmarking. I know and accept the risks as do many others on the forum.
There are many levels of overclocking. Here they mainly fall into two types: like me that want to get the best benchmarks they can, those that want a safe extra bit of speed.
So chill a little and just enjoy seeing some nutter go mad LOL.
Permabanned
10 Nov 2010
Disneyland
That is up to you, after all it's your risk. Both Overclockers UK and Intel say that going over 1.38v is not recommended. Happy frying :)
22 Mar 2009
Fair point, But again, it at your own risk! When I brought intel i7 980x from ocuk I didn't go over 1.38v because i cannot risk it.
Enjoy your biggest overclocking! See if you can go all the way 6GHz ! :)
OP
25 Nov 2002
Somerset
Ok, at last the 5GHz Prime 95 1 Hour stable is achieved.
Took a little more vCore and PLL
That's me happy.
Not about tomorrow, so Graphics benchmarks etc at 5GHz will have to wait till the weekend. I think I have done quite enough for today :)
