Try uninstalling it in device manager and select the option "Delete the driver software for this device" then when you reboot it should detect the card and install a generic VGA Driver. Then try reinstalling the ATI driver again.
Hi guys
Looking at getting a GX660R but have a few questions.
Will this perform better than my current desktop? (in sig)
Will I be able to hook it up to my 22" 1680x1050 monitor and use that instead of the monitor that comes with it if i prefered?
Thanks!
Hi guys
Thanks!
I am having some problem on driver of graphics.
Anyone else having the problem?
Going to update the drivers. hope it fixes the issue.
Thanks for the replies!
Also, how will this lapotp cope with image/video editing and 3D modelling as this is something else I will need to be doing! I'm guessing it will be better than my desktop?
I use an OCZ vertex SSD and it runs lovely in this laptop.
You cannot just turn off raid without formatting unfortunately. You will need to do a fresh install.
Cheers
What steps do I need to take to turn off raid and remove one HDD?
Sorry for silly questions, i'm a newbie to laptop + raid customisation
It that the issue where it cant find a bootable media or some crap? I get that from time to time. Think its to do with having the lan option in the boot list. I tried removing it and saving but it just comes back next boot.
