- 9 Jan 2008
- London/Camberley
Good choice. Enjoy it
I think you should let us know what PSU you are using before installing the GTX570...to make sure your PSU has enough power for it...ok a possible problem... my PSU only has 6 pin power chords to go to the GPU i have at the moment... which card out of the two requires more than 2 six pin connectors?
Which 570 did you end up going for . . . ?thanks guys, GTX 570 ordered and will be in the PC wednesday evening![]()
will report back with a little review on the performance and comparison of the new to the old
cheers
definately not going for the 6950 after recent finding outs of warrenty being void and problems such as bricking or something once flashed?
yes its not an instant bricking thing but it develops relatively fast....
games i currently play include:
Crysis 1, warhead and 2 when its released!!!!
Not sure where that Crysis benchmark came from, but most of the Crysis benchmarks/reviews that I have just checked show the 570 and 6970 are pretty much equal (even at 2560x1600)
I guess anything can be proven with individual benchmarks. It's best to take an overal view including all games, and the general consensus is that both cards are pretty even, give or take a few games that have preferences for NVidia or AMD hardware. F1 2010 for example loves the 6900's and their 2GB frame buffer, HAWX loves NVidia's shader power.
Just reading through the thread again and wondered (sorry, it's a bit late now!) if you should have gone for the 2gb frame buffer since you like crysis. Stock 6950 has better average frame-rate than a 580!
Interesting benchmark, although it is actually the minimum framerate that is better than the 580.
