The *Official* Eve Online Thread
Yeh he hates you for that btw :p If I remember correctly I was there in my Legion and shot your initial tackle a bit before seeing your reinforcements and warping out!
yeah i just pointed the oldest character which was Vimanis and Tengu's are the most likely tech 3 ship to pimp for profitable drops :D
Yeah thanks for rubbing it in, I'll make sure I'll return the favour some day.
no worries... you'll be joining the back of a long queue I assure you :-)... judging by the number of times we come across the same systems when we cycle our static exit we'll soon find each other again... :) though we do tend to ignore C4's like your home WH as they usually just lead to other C4's!
I was gonna abort warp to help out too, but then saw neuty ships on dscan and bailed :( we've done it so many times ourselves we shouldn't really have got caught that way.
Almost had you in the salvager... was within a second of getting point with my nemesis when you warped :S
what neut ship ?!
yeh i had a close call in a Noctis the other day but i pre-sume if it was fRostiE then i was in a thrasher ? :)
you are slow,,,,,,,,,,,,hope to meet you ingame
For some reason when I read your post I am sure you are someone very much like:
I intended solo heh...
Tested againt a Bhaalgorn no sweat, Machariel in full gank might break my tank but probably die to my drones first (or more likely just GTFO as it would be hard to hold one).
if a machariel would get you then a vindicator certainly would... what mystical ship is this and why dont i have it (i have a mach/vindi/bhaal)
Rattlesnake? The drones were the hint :)
Nope not rattlesnake :D tho that would fit the bill to.
Would love to fly an estamel/cap booster fitted snake tho - with my skills could tank 7K dps for over 3 minutes :D shame estamels are 40billion a piece.
i give in:...
cant be cap reliant otherwise the bhaal would muller it...
must be passive tanked for the same reason...
if its passive then its shield tanked...
i assume your using implants and pills :p
Sorry not posting fit heh... have to kill me to get it... and no ones managed yet.
For solo PVP work you'd have to drop tank to around 700dps still enough to kill a bhaal before it gets through the buffer tho.
Really? A properly fit bhaal with 2 faction webs should kill you without too much trouble. The gila is a nice ship but it has its place.
Webs won't make much odds, the ship is brick tanked to the extreme (over 400hp/s raw shield regen on peak).
EDIT: With a fully skilled fleet booster its utterly epic, I've not really used it solo outside of play fights.
