- 6 Aug 2010
- Aberdeen
Yeh but normally looking for distractions at work on 3G
I hate how they all worked on raking in the customers by offering more allowance then reversing it once we are all in contracts.
I am by no means a law buff... but sure that gives you a clause to cancel the contract?
Yes but that's not the point. It's too low for a smart phone like the iPhone. It's just too easy to go over that limit doing a number of different things. 1TB I could cope with, but 500MB is measly. I pay contract so that I'm supposed to be able to just use the iPhone as it was designed and intended to be used. I don't want to be having to top my phone up every now and then. If I wanted that I would have gone pay as you go.
Plus there is no incentive to add the extra 500mb/1TB Bolt on permanently as it costs the same as to have it on when u need it. Why doesn't O2 do a permanent cheaper bolt on? Plus I don't believe O2 saying that most users never hit 500mb. I think they have set it at 500mb knowing that a large % of it's customers could easily hit that. Making it a nice little earner for O2. This would not be the case for 1TB per month.
You should probably consider investing in that new fangled technology called WiFi, I hear you can even get it at home now!![]()
Or if that didn't work I guess she could just cancel her contract, take my sim and number. I just get a new sim and number for Giffgaff or 3 mobile. Only problem being hers is a iPhone 3Gs and wont take a micro sim! Arggghh...!
Is anyone on the simplicity plan from before the 500mb cap was put into place? I got a text ages ago saying I will be moved to a 500mb cap but iv gone over that a fair few times now and never had a text or email.
(only averaged 150~ms pings) and went up to 1.2GB with no extra charge.I think you'd struggle to hit 1TB/month tbh...![]()
this
i was strugling with 500gb, then bought a new wireless router and all my problems with data on IP4 have gone
get wifi brother its all the craze, all the cool dudes are on it lolz![]()
You can just get a micro SIM to normal SIM adapter. The micro SIM just clips into a plastic plate that makes it the same size as a normal SIM card. I got one from o2 when I got my iPhone 4 (not entirely why, it was just bunged in the bag).
Yep I'm on the older tarrif still, in December I was using my phone tethered to my pc for online gaming(only averaged 150~ms pings) and went up to 1.2GB with no extra charge.
I thought O2 were eventually phasing out all unlimited old contracts/tarrifs to the new 500mb cap??
Must say i'm having same problems with there limits, I'm using it a lot for streaming spotify on my phone, while in the car or running ect.
But thats what Im saying. Thats what O2 should have set it to, like Tesco did. Is Tesco still 1TB?
