I think you missed my reply two posts up mate.
Let me quote what I said.
Increase in frequency does not produce heat. Not in itself. It is a common misnomer, but I suspect it is because most of the time when frequency is increased it is because voltage has been added to facilitate the increase in frequency.
But it is easy to test.
You take your CPU and set your voltages at a fixed amount.
Then take a reading of the temps.
Now increase your frequency of the CPU without changing the voltage at all.
Let us know what you find. I guess you will find your results match what I have found when we tested with students. No increase of temperature.
You see heat is energy and energy can not just magically appear it needs a source. Thermodynamics as I said earlier. So to have any increase in thermal product or heat it takes an corresponding amount of added energy, therefore there needs to have been a source that provided that additional energy.
But I do agree with you.
If you push too much energy into a CPU yes you will kill it. And since my comment is causing some confusion I shall remove it if you prefer.
