After a very nasty near miss earlier, I have decided to dig up a thread I posted a while back in Motors.
trucks have massive blind spots, after a brief chat with a biker today who I nearly wiped out, it was apparent that he thought I knew he was where he was when infact I did not.
Almost classic case of "Sorry mate - I didn't see you" if anybody remembers that far back?
The biker in question was trying to pass me on my near side on a large roundabout - as I started to straighten up, thankfully, I saw a reflection of his light on the road behind my trailer!
He was lucky, I had enough space (i.e no on-coming traffic as I exited the roundabout) to swing out wide right & avoid him.
No harm done, we shook hands & went our seperate ways as friends (unusual for some bikers & truckers!
So I hope this post is taken as intended, as advice.
I'll be the first to say a lot of truckers are complete ****'s and are indeed a bikers worst enemy!
Blind Spots in & around HGV's.
Here we have a diagram that roughly gives an idea of the field of vision for the average artic driver.
Most of this is fairly self-explanatory - Hopefully it's helpful.
The truck cab & trailer is the blue bit.
The darker the shade of green the harder it is for the (truck) driver to see you-ASSUMING HE'S LOOKING IN THE CORRECT MIRROR!
Red areas are completely blind to the driver.
Note the blind areas directly in front and to the right of the cab. They are big enough to lose someone pushing a bike flat against the truck.
Pic1
Pic2
Pic3
Pic4
Pic5
Pic 1) and pic 2) Truck turning left/on a left hand bend.
Rear of the trailer will be moving closer to the kerb and further to the left than the cab.
The cab will be on the white line or even crossing into the other carriageway depending on how sharp the turn is and how wide the road is.
The Driver is HIGHLY unlikely to be looking in his right hand mirror unless to check if the corner of the trailer is in the right hand lane-and all he'll see in it is the headboard of the trailer if he is.
Predominantly he'll be looking in the left mirror/ahead.
Pic 3) Truck going in a straight line.
This is also the same visibility as a rigid or non-articulated vehicle. Assume the driver is using his mirrors only in the direction of travel in a rigid vehicle.
If the truck is stationary or it's safe to do so-(i.e. assuming no oncoming traffic there needs to be no bends in the road coming up and the truck isn't indicating) then this is the safest time to overtake.
DO NOT UNDERTAKE while it's moving-and if you MUST undertake then only do so if you KNOW the truck isn't going to move before you're past.
DO NOT pull up in the nearside red zone by the cab.The kerbside mirror shows very little.
If the driver is going to miss you,unless you're directly behind the trailer this is where he'll miss you while the truck is stationary.
We'd far rather you pulled up directly in front of us and we could see you.
Pic 4) and pic 5) Truck turning right/on a right hand bend.
Rear of the trailer will be on the white line or even crossing into the other carriageway depending on how sharp the turn is and how wide the road is.
BEWARE the back end of the trailer-if this is a very sharp bend, the rear of the trailer will be moving to the left as it pivots round the axles.
This is a SERIOUS crush hazard and the driver CANNOT SEE IT at all and is unlikely to know the trailer has hit someone.
The Driver will be splitting attention between right mirror(back of trailer),left mirror(Is the headboard going to intrude on the path?) and ahead.
If an articulated lorry isn't stopped in a straight line DON'T undertake. Your chances of being seen are slim if the trailer is bent left and nil if its bent right and you're likely to get crushed as either the cab or trailer will be coming very close to the kerb.
For the same reason, don't ride up behind one in the red zone at speed then pass-the driver may already have committed to a manoeuvre because his mirrors look clear.
I hope the powers that be sticky this for a while.
Cheers.
)So I hope this post is taken as intended, as advice.
Pic1
Pic2
Pic3
Pic4
Pic5
Cheers.
