It'll also age better if you're a moderate gamer on a moderate resolution because in a few years time it'll still be able to do the job - at low/medium detail.
And a 480 won't? Why not? What does the 480 lack that the 560 has?
[TW]Fox;18347321 said:And a 480 won't? Why not? What does the 480 lack that the 560 has?
The extra memory may come into it. As you correctly pointed out it may not.
But 3 or 4 years down the line, the difference in performance will be less stark between them, and the extra memory will still be there.
a GTX 480 should be somewhere around 4x faster then your 8800gtx
Only you can answer if you need or want to buy now or wait..
The trouble with benchmarks is that they are giving you a range of framerates in a very specific set of circumstances. These circumstances cannot possibly account for every situation that occurs whilst actually playing the game.
There is always the 5950 flashed to 5970 which is 10dB quieter and uses significantly less power, or if you're dead set on Nvidia then you always have the option of adding a cooler to solve your issues later - there is no cheap option to solve the issue of lacking v-ram.
[TW]Fox;18347356 said:But you just said the 560 would age better. Why? What about the 560 would make it age better than the 480?
There's no way to tell. I'm guessing that in a few years time when both cards would struggle with medium/high detail on 1680 resolutions, the extra memory may be a consideration.
Conjecture maybe, but it is no worse than relying on a test that will not necessarily properly factor all variables, there for not really indicative of real world performance.
As for V-ram, as stated, it all depends on where you look.
[TW]Fox;18347029 said:I'm not sure I agree. See my comments earlier - by the time 1Gb is a big problem the card is junk anyway.
I wish this was simpler and easier. The 560 Ti SOC seems the better choice but the 480 just seems more.. heavy duty, which is also appealing![]()
I think buying a 1GB card now saying "Yeah well, I just won't play with a decent amount of AA" or "I have no idea what will happen with games coming out, but I'm guessing they won't use over 1GB" is slightly moronic.
[TW]Fox;18347386 said:But you specifically said the 560 would age BETTER - was that a typo then?
No, because I think it will..... I don't know how else to explain it. I think in 3-4 years memory demands on graphics cards will be higher than they are now.
No, because I think it will..... I don't know how else to explain it. I think in 3-4 years memory demands on graphics cards will be higher than they are now. 3-4 years ago memory demands were less than they are now. I think that'll be a bigger consideration than the slight difference in FPS scores the two cards get.
Are some people in this thread deluded that their 6950 or 560 OC (that they paid more for) is a match for the 480.
