So cutting to the chase, are you guaranteeing as a representative of OcUK that there is no risk of data loss associated with this issue?
Good question.
Well if the Sata port ceases functioning completely mid write, what are the chances of data loss and/or data corruption?
Exactly the same as if you were writing data and had a power cut and did not have a UPS.
You will loose the data you were writing for sure, causing that data to be corrupted, but all other data would be intact.
Thanks Gibbo. When I get my board back i'll be putting my SSD and data drive on the Sata III ports and only my optical on the Sata II port.
Classy.
Look up what insinuating means because it pretty much covers:
I'm being pedantic because I'm concerned about possible data loss and the downtime that will be caused if it occurs. Also the general vagueness of the reports make me suspicious as the only people saying don't worry your data isn't at risk are people in this thread.
You could set up a raid 10 array with 4 of the sata 3 ports, then scritpt so continually copy and delete files from the volume..
Set it in motion and have a log counting iterations, see if it starts to degrade over time.
You are pretty much right.duncanm, as someone who is just following the threads im not taking sides i have disagreed with OCUK many times, personal insults are not welcome on here so i choose my words carfully:
Your post are coming over as you acting like a plonker, chill out wait untill ocuk has more info and stop going like your data is MI5 we all have p0rn.
on a serious not just take a breath dude it will be sorted one way or another![]()
Will just disconnect the drives and grab a controller if it's going to be a long wait for a fix.
As much as anything getting rubbed up the wrong way by people saying don't worry there isn't a problem instead of know one really knows but you should be ok.
Actually most of the data is a mixture fraps and video footage that I haven't got around to properly editing.
6TB of porn would be O_O
Exactly. And the fact that it doesn't kill HDDs![]()
I'll play devils advocate here...
My one week old C300 died today.
I'm not saying it was down to this fault, but no one can be 100% and claim it wasn't either.
You have (had) an SSD not a HDD.
What about us who have to use the 3gb ports ?
