... what would you say is a good 24/7 overclock for these chips?
Best BANG for the buck. The key word here being BANG!!!
Expensive hobby this push to the limit overclocking lark. I prefer to overclock to save money, but great skills on getting it there!![]()
You know that is exactly how I started. I bought a really cheap CPU (my first Intel system) and wanted to have the same performance as the top of the range CPU. Next thing I knew I was benching.
Beware there be dragons.
The SB is very good on water. The H50 or H70 will drop your temps by 15'c. .
I'm finding the H70 works very well with SB, I can idlle at 15c and has never gone above 65c at 5.Ghz
