Did you check all the box? Mine was in the outer cardboard box, not in the inner packaging.
Oh yeah there it is... I was too distracted with the fancy black and gold Asus box (and the 480 as well obviously)
It appears I have missed the GTX 470 deals, is this worth the extra pennies over that?? I am new to PC gaming so have no idea what to expect with regards to benchmarks and FPS etc
Sorry for n00bish question
well - I just hit 'go' on the order for delivery tomorrow. Hope that the thing is not too loud - but sitting here listening to the my Dyson 4870 (tm) I can't imagine it will be.
Looking forward to playing with it tomorrow...
Funny thing is that in the 3d profile thing it says it works excellent or something... 3d at 10 fps must be awesome
should have got a 5870
Dyson 4870? You are in for a bad shock, the 480 is louder at stock idle than the 4870 is playing games![]()
No it isn't.
My 4870 runs all games @ 70% fan, which is not as loud as my 480's stock idle setting. So yes it is.
What % is the 480 running at idle, because at idle it should be 44% which is silent.
[TW]Fox;18389810 said:44% is not silent at all. Infact it's very audiable indeed - 30% could be considered by some to be 'silent' but 44% most certainly is not. We've already established it seems what your card thinks is 44% is rather different to everyone elses.
[timko];18387462 said:You can't really connect any of the plugs into the wrong place unless you use a hammer to force them in. They have added notches, odd shaped heads etc to ensure that each type of plug only goes into specific places. No need to worry about it so much.
Since this is your first PSU transplant, I would right down the number of things currently plugged into the old psu, preferably along with the type of plug each device etc it's plugged into.
Then check that list as you connect the new PSU up one plug at a time. Make sure you've connect up at least as many plugs on the new PSU as you unplugged from the old one. That way you can't miss any. The final count will be 2 units higher since the 480 takes up one 6 and one 8pin PCIe power.
As for the location of the graphics cards, if your motherboard as two full 16x lanes (which you probably don't know) then it won't matter which way round it goes. However, in the more likely event that your motherboard has a 16x primary and an 8x or 4x secondary slot then you definitely want to move the 9500 down. Do you know the make and model of your motherboard? If not it doesn't really matter, just put the 480 into where the 9500 is now and you won't have to worry about it![]()
