Go and read Techpowerup, there is a way to mod your bios so it has the unlocked shaders. Then you can overclock manually to whatever the card limit is.
Flashed my 6950 to a 6970 shaders+clocks and was getting heavy artifacts in 3dmark and heaven so i flashed back and they seem to be gone, now i only want the extra shaders but keep the 6950 stock clocks, how can i do this?
Worked perfectly thanks im not going to bother overclocking just yet but is it worth increasing the power controll settings in CCC?
No problem matey. Good job.
It's meant to only be of use in Heaven 2.1 benchmark. Funny thing was it gave me a very slightly less score with 20% than with it at 0% so I just leave it at 0% all the time. Others did see differences so test it in Heaven benchmark and see what you get.
You will only still have the 840Mhz max in the CCC to overclock to but you can use MSI AfterBurner to reach higher. Remember though that you're at 1.100v so you'll only get about 880-900Mhz on the core clock at this voltage. If you want 950+ you'll need 1.175v+.
1.175 is the default 6970 voltage but I've read it's recommended to stay within 1.100 - 1.300v. I used 1.225 to reach 1000Mhz on the core but for what I'd have to run the fan at to keep that stable I just went back to 1.175.
Ok nice one i might try bump up the clocks a little later on when i have time, thanks.
.so asus 6950 seams to be the consenus. i have never changed bios on a gfx card is it hard to do and what are the dangers to long term life.
I have vast experiance with cpu overclocking and gfx card just not bios changes in gfx cards. could you give me the idoits guide those lads who have already unlocked them to 6970's im running windows 7 64 bit on a x 48 mo bo
[TW]Fox;18394350 said:So if I was to buy a card to do this with, which is the best brand to go with? I noticed in another post somebody was saying the fan speeds/noise on the Asus were higher.
I've been happy with my XFX GTX280 so for some reason seem inclined to favour the XFX 6950. Is this flawed logic?
Just buy the cheapest. I have the OcUK one, which is Powercolour and its quiet enough, although I believe they are all reference cards so should, in theory be the same.
Maybe he just has a "bad" card that can't OC as well?
