Rift: Planes of Telera Beta
have you seen the mounts at lvl 50 cost that cost 120p , look awesome, getting a bit carried away i know ;)
they are indeed marvelous looking... specially the metallic gold one's..
thats good if you can get xp by only pvp'ing...
what level you need to be to do that ? 10 as mentioned ?
and where is this Warfront :)
I have 2 or 3 toons and highest is like 7 or 8....grinding from the beginning puts me off....but if I can on to pvp from 10 I will give it another go :)
as soon as you hit level 10 on the bottom left of your UI are about 10 icons, there is one for Warfronts. Depending on how many are wanting a match the queue's are usually every 30sec to a few mins,.. one good thing the game does is pick players from across all the servers and not just yours... hence why you see XXXX@Sagespire or XXXX@Cloudborne etc etc
You can also level just as quickly doing instances and dungeons. Trion have said that there will be no lockout timer on normal dungeons so you can use them to level up. That's actually similar to their exact words, so basically they encourage it.
Another good way is to get a group of friends or guildies and just go Rift hunting. I did this in the second Beta with about 20 other people. I went up from lvl 10 to 15 in about 2 hours. :) It reminded me of some older grind based MMOs where there were few quests and you gained XP just by grouping up and go on a rampage. :D
yep, I agree that must be awesome fun but for this last beta I was not guilded and was just trying out many many many different class types.
I only managed to get one of about 10 toon's to level 20 and had no idea of how to venture away from Freemarch !! hopefully someone can shed light on that problem for me :p ...
bored bored bored now...
current beta is cloed isnt it? Open one on the 15th.
meh oh well.
There's two betas running, the proper closed beta where they are bound by NDA and these 'preview' weekends with which the NDA was lifted a couple of months ago.
As for the game itself, i got bored with the casters just using the same spells over and over due to cast times being too long to be worth it on most.
Hi i play rift and was looking for help with a problem.
The problem i have is my game crashing on me so much yet its random sometimes when there is a lot going on sometimes when there is nothing happening.
Warfronts crash me a lot too yet i just cant find out how to fix it tryed everything so far.
Winsock reset
Revert back to 10.9 drivers (they told me to rift gms)
Turned off all crap that dont need on.
If anyone can help i would be very happy
My specs
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_gdr.100618-1621)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: GA-880GM-UD2H
BIOS: Award Modular BIOS v6.00PG
Processor: AMD Phenom(tm) II X6 1055T Processor (6 CPUs), ~2.8GHz
Memory: 4096MB RAM
DirectX Version: DirectX 11
Card name: ATI Radeon HD 5800 Series
Manufacturer: ATI Technologies Inc.
Chip type: ATI display
Thanks for any help
umm take a look closely at the pic above. someone said that your character doesnt get reset when you pre order and get the early access?
Well when you get early access that is launch so there is no reset. OBVIOUSLY there is a reset after beta.
Winsock reset
My specs
Memory: 4096MB RAM
Thanks for any help
Have you tried running the game with all graphics settings on minimum and at the lowest resolution? Does it still crash?
After you crash have you checked the Windows event viewer to see if there's any hardware/driver or system errors?
Have a look inside your case, is there anything getting really hot. Maybe GPU or CPU is overheating.
Does the game run strange before it crashes? Any graphical artifacts? Any sounds issues?
Finally, do you play other games and do they crash too?
Yes to this
Yes nothing wrong
Yes its nice an cool inside nothing out of place
No it plays fine then just crashes
I do play black ops on full setting and have no problems runs great
I cant work it out why its crashing my card can handle the game and my system could it be my internet thats not the best ?
Wish there was a fix for me i really want to play this game :(
Although I won't be playing the game at release I did have the same issue with Rift, no internet problems or with any other games very similar spec as well - unsure why.
so can we get early access via steam or not ? if not, need to check how to get refund lol ...bought it few mins ago ...
ok, emailed STEAM to get my money back from RIFT...should be fine as it is pre order...
asked them about head start as well...if they want to keep my money thay have to answer it and say yes, you get head start as well ;D
if not, will get it from TRION
