Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Re: garlic bread
Dead simple, and the cheat way but also nice, this is what i do.
BUY the baguette, get 2 small ones rather than one large. M&S sells the nice size one and fresh daily.
Get some butter, fresh garlic and parsley or chive.
Peel and crush a few goves of garlic into a bowl
Chop up some parsley
Put it into the bowl with the garlic
Add in some butter and mix it up
Slice the baguette up anyway you like, i like it across but not all the way in.
Spread the garlic butter on
Into the oven at medium heat for about 10 minutes max, I woud check it after 5 to see, if its brown then it's done.
When it comes out you will have warm, fresh garlic bread.
. Just gonna go make a salad. Nah just gonna go make me tea and toast
