- 8 Aug 2010
- Oxfordshire
Secondary settings screen, better burst, better buffer, better build quality, second settings dial, lots of small things add up to a big difference.
1) Secondary settings screen (no biggy imo)
2) better burst (no biggy unless shooting sports)
3) better buffer (Use fast SD card)
4) better build quality (More robust & good if in rainy weather, adds weight/less practical for carrying for long periods)
5) second settings dial (no biggy imo)
Well done, you listed a bunch of stuff that doesn't impact image quality, or really the ability to capture an image, with exception of higher burst/buffer, which is mainly useful when shooting sports etc.
Settings are subjective, IMO, it all depends on what your used to, I hardly have any issues navigating a 550d and really like the controls, I'm sure if I moved to a 7d I wouldn't like the all of those controls buttons at first, until I was used to them.
Bottom line though, I obviously wasn't arguing that the 7D wasn't better (hence why I didn't like the failed attempt at being funny), but that only aside from a few select circumstances, a 550d can deliver the exact same (or extremely close) results and image quality as a 7d.
I have a friend who thinks her 550D is just like my 7D, and it's laughable.
550D is a fine camera, a close competitor to the 7D it is not.
Barnaby Britton and Simon Joinson @Dpreview said:Confusingly however, apart from build quality, the 550D has more in common with the prosumer EOS 7D.
The new camera also inherits the EOS 7D's sophisticated metering system (which brings it a lot closer to similarly positioned Nikon SLRs).
So why has Canon apparently risked cannibalizing 7D sales by releasing such a similarly-specced, lower-end model?
Ummm... yes it is, unless your a camera snob.
Edit: Comparison
550D Vs 7D
I'm perfectly happy with you just preferring the 550D because it does exactly what you want, that makes it the ideal tool for you and you saved money to boot
