ok so whats the deal, do u still use speedstep for multidrop and if so are you applying any offset etc or just leaving the vcore static high and low multi?
glen
How you know how many watts your cpu is drawing ??ok
3.3ghz stock 62watt desktop 90watt full load
4.2ghz 62watt desktop 107watt full load
4.5ghz (.944v) 62watt desktop 114watt full load (1.248v)
4.5ghz playing 2 HD movies + internet (cpu 15-19%) [email protected] 69watt load
System has 2xsata HD's in raid and dvd but only an old pciex gforce card
Quite reasonable I thought
or is this the wattage draw from your whole system ?
Hi Elevonchaparral quick question on the 9900 back plate mount bracket,is it plastic or metal ,reason I ask is if its metal then there's a chance of it shorting the board from underneath when its connected?
From what i understand they won't be limited as the PCI-E slots are version 2.0 which have double the bandwidth compared to PCI-E version 1.1 slotsAren't the two GTX 580's in SLI very limited on board that can only run them in the two PCI slots at X8/X8 ???
Hi Guys,
I have the Asrock P67 Professional board but I am having issues selecting anything higher than the 46x multi, when selected the board posts fine and then I just get a white flashing line in the top left corner of the screen and nothing else.
I'm not sure what it could be as this is my second board as the first one kept on playing up, I have tried 4 different bios's and made changes to all the voltages to no avail. The 45x multi works fine without issues.
Any Ideas?
Can you post a complete list of your overclock settings? I've been overclocking since I had a Cyrix 166+ but this is seriously confusing now.
I had this problem when i first tryed clocking at anything above 46x..I have no issues running at 4.5ghz with 1.25v 100% stable
I have pushed the vcore up to the recommended max of 1.38v but it makes no difference, the board will post fine with the 46x multi, it just refuses to load windows even if I use the pre-set over clock I get the same results.
It's either the CPU has hit a hard wall or I am missing something?
