Right flashed to unlocked asus bios from the zip you gave me, but smartdoctor doesn't unlock the higher clocks for me. I followed the instructions to the letter. After uninstall of smartdoctor and launching ccc, top clock available is 840. Any ideas as to why the limit is not higher? I have had Afterburner 7.2 beta installed from before I did the unlock 50 bios flash. I don't know if this has anything to do with the problem.
I would not use a 70 BIOS. So yes, I would put a 50 BIOS on you first card too.
It's a HIS, Afterburner was already installed prior to the flash, but if you go past 840 in afterburner, then ccc starts flickering. I was just after the 880 clock of the 70 bios. Ideal for me was 880 on the core with 1300 on the memory.Not entirely sure why that is, I'd try using afterburner with unofficial overclocking. I haven't actually heard of your problem, what brand of card are you using?
Yes, i got a flickering black screen when it was applied, so I presumed it was doing something.did you enable overclocking range enhancement ? before uninstalling ?
Ok maybe it's because I'm new to this but this seems more confusing to me
Should I go back and reflash my first card too?
I'd be more comfortable with just flashing to the 6970 bios as I know what I'm doing
Is the 6970 bios that bad that it's not a good idea to do it?
If you do decide to reflash your 1st card, shaypers link and instructions are very clear and pretty much just as easy.http://www.megaupload.com/?d=8FHEMTE0
Bing
A whole unlock thingy with the ASUS bios, gives you extra voltage for free, a tiny OC and unlocked shaders. Perfect?
And it's no worries, happy to help![]()
SORTED!!!did you enable overclocking range enhancement ? before uninstalling ?
I'll also use winflash and probably flash both to 6950 bios unlock
Will I need to use one of the over volting tools with this as with the 6970 bios I've just been using ccc power tune
Thanks Shayper, that's me a happy man now.Nice to see you got everything sorted tommy, happy to help![]()
