I would go for the Crucial C300 to take advantage of the SATA 6 Gbps ports on your board. What's your budget by the way? This one would be ideal although may be too expensive perhaps.
Hold out for the next gen which i believe is starting to come out next month although I may be wrong
Don't use the marvel 6Gbps sata ports as there much slower then the intel 6 Gbps portsI ordered the C300.
I was just wondering, Which port should i plug it in when it arrives. My mobo has some Marvel ports but not sure what they are. Should a SSD go in there?
