The bullet has been bitten [2nd 6950]
Didn't know you had to do this, didn't see it in any threads I came across
you not looking in the right places then
that quote i added up above is from an answer to the exact same question i asked over the new year
Off topic.. Why you selling your 6950 crossfire setup out of interest
moment of maddness, it happens from time to time
ive changed the cfg to value 1
no luck, am i suppoosed to be using version 2.10 beta 7?
damn, i was reluctant but ive bought the asus 2gb 6950 card
hopefully it should allow everything produced for a while to run smoothly maxed out,
and if it turns out to be not worth it, at least it helps heat my room lol
a few questions .. maybe stupid
- running 2 monitors, do i plug both into one card, one in to each or does it not matter?
- is it a good idea to underpower these in CCC to save some heat? obviously the full power will not be needed for games to run smooth
-any other matters i should be aware of? [new to multi gpu]
- maybe i should flash the bios, but use bios setting 2 until i need the extra?
wow, you joined in January and almost 1000 post already :p
yeah January last year, and believe it or not i have a gf lol
my first pc build and i have lots of questions
yep AB has voltage enabled, i found that myself after i posted, thats unlocked correctly
al4x, When did gpu observer start working with 69 series? It wouldn't work for me. I just found 3.7, is that the one your using? I'm at work so I can't try it yet:(.
Yeah the latest one 3.7 works and it allows you to select multiple sensors, I use one for each card
Also I've been having bsod with afterburner, do I have to disable ulps in windows registry to get it to overclock the cards?
yes disable ulps
u got a guide for that ?
Go to registry and disable Ulps:
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Cl ass\{4D36E968-E325-11CE-BFC1-08002BE10318}]
and change "EnableUlps" to 0 under the 0000 and 0001 or 0003 keys.
taken from another nice forum
yeah ive changed registry before,
like before the main bits im unfamiliar with is bios stuff and overclocking [as well as being over cautious cause one wrong figure followed by 'enter' ruined hardware]
id like to say thanks to all the people who have helped me out with this in this thread. :)
also as far as i know thats the last thing i have to mess with to achieve this
al4x: In afterburner config (the same one that's in your screen shot above) you should add this to it
^ now the beta 6 is already working I think I'll stick with that
I guess I needed to stick that statement in
ok if powerplay doesnt work im using beta 7
have applied the fix and its all working now, the BSODs no no longer happen, everything in afterburner works
im clocking each card in non crossfire mode as yet as i dont know if you can do it with crossfire enabled, [im guessing you can]
i knew the g15 mini lcd display would come in handy for something.. amd its displaying the stats of each card [V,clock,temps] :)
i guess apart form the crossfire or not when OCing thats this done!
thanks to everyone for walking me through this, i expect ive tried your patience at some points! :)
ok this is not the end of it, now one of my gpus is at 100% usage with no overclock just pressed apply in msi afterburner with a tiny voltage tweak
Sometimes I think this has not been worth it
Now msi boots at start up but one of the 2 cards goes to 100% gpu usage,(that's what msi is reporting along with temp increase)
I then load gpu z and it drops back to zero like it should but card one doesn't then click any higher that stock 810 and 1200
Driving me mad.. I don't want to have to boot gpu z every time I load the pc
to elaborate further..
with CF enabled
Card one will not go above stock 1.0mV, and stock clocks, soon as i click apply in AB it just defaults back
card 2 will but sticks at 100% GPU until gpu Z is activated
with the above opening a 3D app .. ie a game.. card 1 jumps only to 810/1250 but card 2 does show what i request including voltage
im going to try with CF disabled tomorrow, otherwise im just gonna sell the second 6950 and wait for a better single card from amd later in the 7xxx series
[tried something else, now card 2 will not clock but card 1 will, and without CF i cant get AB to work at all, clocks are set at 0/0 no matter what i do]
