- 14 Dec 2005
- Bath
I've done something to my PA Foam Lance
Put it away after using it fine and then the next time I came to use it it seems broken... It doesn't foam up properly and just sends three sharp jets of foamy water out (one to the left, straight ahead, and one to the right).
Ideas anyone?
Nilfisk C120 3-6 is what I use. My first and only pressure washer though so I've got nothing to compare it to!
And yep the Kew/Alto one is the right fitting
Ideas anyone?
Hello chaps.
I need a recommendation for a new pressure washer as I've finally killed off my old Karcher today. I understand that Nilfisk are the weapon of choice for the discerning cleaning enthusiast, but I've a little baffled by all the choices - any advice would be appreciated - let's say the budget's around £100 but can be stretched a little further if necessary.
Oh, and will I need a new nozzle for my PA Foam Lance? And would that be a Kew/Alto one?
