- 29 Dec 2007
- London
i cant seem to get any to work! could anyone point me to a guide for noobs or something? not really done much modding thanks
From a fresh install of gta. Install the 1.0.4.0 patch.
download the enb series files from http://enbdev.com/enbseries_gta4_v0081sora.zip and put into the main gta directory in program files.
download the .dll from http://enbdev.com/d3dx9_40.zip and put into the main gta directory in program files.
copy the timecycle files to:
C:\Program Files (x86)\Rockstar Games\Grand Theft Auto IV\pc\data
copy the visualsettings files to:
C:\Program Files (x86)\Rockstar Games\Grand Theft Auto IV\common\data
extract the shaders.zip to:
C:\Program Files (x86)\Rockstar Games\Grand Theft Auto IV\common\shaders
copy the remaining files (excluding folders) to C:\Program Files (x86)\Rockstar Games\Grand Theft Auto IV\
Then select one of the folders for weak or powerful pcs. copy the contents to C:\Program Files (x86)\Rockstar Games\Grand Theft Auto IV\
in the main gta directory one of the files you just copied will be called enbseries.ini open it and find the following lines.
ForceDisplaySize=true
ForceAntialiasing=true
DisplayWidth=1280
DisplayHeight=720
AntialiasingQuality=0
change the display size to your correct res. the AA quality goes from 2 to -1 (2 being the best performance). The machine in my sig is pretty much a slide show on 0.
Start your game - the menu may not appear properly and you'll only see the top left corner of the screen. In which case press enter or the green button on your xbox controller to continue to load your game. The screen should resize upon actually loading your game.
