I've had a gtx570 for a few month's now and quite recently Nibitor 6.0 came out and I've been playing
Totally disappointed that I could not edit the fan settings, save for min and max speed I thought I would see what could be done with the voltages
My card was running 0.912v idle and 0.962 (full 3D)
Dropping the idle voltage to the lowest the bios is happy with is simple, but I wanted to drop the other 3D voltages, I'll just cover the full 3d setting here.
Started lowering the vcore as far as I could go which was to the low 3D vid 0.913v the card was still 100% happy benching Crysis etc, as I could not go any lower on the volts I thought it best to start overclocking the core.
Well by the time I'm up to 800mhz on the core and all is well I'm thinking hang on it can't really be doing this...double checking with other monitoring software etc.. Well it eventually gave up @ 820 on the core !!!, I think that's pretty stunning
Settled for a 0.925 max vcore, so I can easily up the core to over 800 if I need to without adding any extra volts
But on that note except for Crysis the card is so powerful (and I have not got My head around why) in My sandy bridge PC that I don't need to....example F12010 in My old E8600 @4GHZ used to give at the settings I run about 55FPS av this same GTX 570 gives 120FPS av (109 min) sure that game must be very CPU dependent but other 3D benches have scaled incredibly.
Quite sure You could take the other angle and get this card up to near 1ghz and really chase some benchies if You wanted to
Update
Seems I was way overvolting My core
@ 0.92volts, with the updated bios I could drop the P0 (full3d) power phase voltage lower for testing (P8 phase voltage was limiting me to 0.92v ) ...ready for this
Now running P0 phase (full 3D) at 0.88 volts and it is happy on the core at full load up to 760mhz (I did not try higher as it hurts me to crash components) so My stock 732mhz is 100% solid.
I can't tell You exactly how much the temp it has dropped (as I also have a problem letting my gear run much over 60c) but I would guess stock (near silent auto fan) would have been mid 80c while testing on auto fan it's now mid 70c with the fan only going to 50%.
The full 3D power has dropped about 30watts (that's 2.5amps less on the 12v rail) and of course the performance is identical to stock
I've posted this not to "big up" My card or Nvidia , just because I'm sure it would be of interest to a few of the more discerning Guys out there, and I'm sorry if some of You have GTX570's that need more voltage.
Remember If You want to make Your GTX570's graphics performance increase, Don't reach for the "overclock tab" get the rest of You system up to at least an equivalent 4.4GHZ sandy bridge performance.
I would like to thank Orbmu2k for his fantastic Nvidia Inspector tool http://www.orbmu2k.de/
and Mavke for Nibitor 6.0 http://www.mvktech.net/component/op...temid,26/func,select/id,135/orderby,2/page,7/
Cheers
Update
Cheers
