Proper VM Coax
10 Jul 2008
Do you want some? I have some left over from my old house when VM were NTL. It's a particular type, try google I don't know the name.
OP
25 Dec 2009
London, UK
There we go, I didnt have to login.
6 Aug 2007
You need to get a new modem, VM stopped giving out Scientific Atlanta's about 4 years ago. Ring them up and tell them your modem is ancient.
They should then send you a shiny new Ambit 255/256 modem free of charge.
3 Jun 2005
The South
You're probably thinking of the Motorola Surfboard, the SA is a Cisco modem (replaced the Ambit's) and it was only superseded by the Hub/Super Hub.
As long as the coax cable used is R6(R59 if you have to)/HD100 then you shouldn't have any problems. As PistolPete said, it's probably an issue elsewhere.
Does it appear to be capped at 300kb/s or does it fluctuate throughout the day?
Best bet is to get onto the cableforums.co.uk forums and ask on there, plenty of VM/NTL/Telewest engineers that'll be able to help you.
OP
25 Dec 2009
London, UK
Ah nevermind guys, I thought their was a problem but their isnt its the damn seeders, XD, sorry guys :S.
One more question the other day i checked my speed on speedtest.net and it went to like 19Mbps -/+, and the max speed i can get is 1.1MB/s
KIA
KIA
Man of Honour
14 Nov 2004
Probably caused by Internet Security software.
Can't type for toffee
Don
14 Jun 2004
Newcastle U/T
You can't use torrents to guesstimate your speeds :p
Only as fast as the slowest connectiona nd all that jazz :p
Deleted member 651465
D
Buy some foam shielded Webro WF100. Vastly superior to RG59 and R6.
