- 28 Jun 2006
- Newcastle upon Tyne
I use the JJ ROM and I've had one crash since I got the phone - which may have been more related to my impatience
I can confirm that. CPU overclocking does not work in the FLB R10. Everything else is sweet though. Great ROM.Rom works fine but overclocking does not.. Will investigate later..
Try FLB? As said earlier, I had signal issues with the early JJ roms.
You have unlocked it via unlock code haven't you?
Anyone with FLB R10 had issues with switching between wifi and 3g data?
I bought ROM Manager Premium - https://market.android.com/details?id=com.koushikdutta.rommanager.license&feature=top-paid
It automatically checks for updates, and gives me the option to download and install them over wi-fi, brilliant!
Updated mine to 12 this morning, didn't wipe though, all seems good so far.![]()
ive gone back to JJ9 permanently now, wont bother with CM7 untill the battery drain issues, poor camera quality, screen wake after calls is fixed.
Cool. I'm far too tight to pay for things like that though, launcherpro etc.. just give me the free option![]()
For me CM7 was a whole lot more sluggish and choppy in the menus than any of the Froyo roms and with CM7 draining my battery in around 10 hours it was just too much.I can live with the issues for the speed boost, everything just feels that little bit more responsive, and hopefully things can only get better.
