- 3 Jun 2005
- The South
YES that's EXACTLY my problem, I saw this forum before, should I keep going to service pack 2 or 3 or whatever it is on win7 at the moment and then try?
Exactly as that forum talks about, I can't get the firmware updater to work
I struggled to update the firmware on Win7; luckily I had a XP sp3 laptop to hand and the firmware update worked without a hitch. Then it was the simple case of removing any trace of old drivers on the Win7 system and install the latest drivers.
Regarding the Mac Vs PC; from my 8-9 years experience working with both systems in audio/studio environments (OS9-10.6, win98-7, Protools LE/HD and various other gear), you won't notice much difference in a home studio environment. It's only when you're needing high track counts and loads of plugins do Macs/OSX come into their element ie: slight better and more efficient performance (same plugins tax the cpu less etc).
Also don't believe Macs are any more stable, you can still happily crash/beach-ball them.
Personally I’d spend the time getting the Multimix working and use the cash for better gear. You can't have enough gear
And Logic, eurgh
Late Edit - Do realise Cubase/Nuendo runs on OSX
