***Official Unigine Heaven 2.5 Benchmark Scores***
Status
Not open for further replies.
2 Oct 2009
Belfast, UK
With application controlled settings
5870 at 1025core 1250 mem
:Edit: Didnt realise we were doing 1680x1050 :) Will edit post with updated results :: Edited
4 Jul 2009
GTX 580 @ 990/1980/2300
Upped the core a little, couldn't get to 1ghz. Also forgot I had AF and AO settings and some filtering settings turned up in control panel, now at default.
15 Mar 2010
Can't post screenshot atm but my 570 @ 900 mhz got exactly 60.0 fps, about 1600 score.
Edit: I'll deff. need to retest when I get home, 60 fps seems a bit high compared with a higher clocked 580
Man of Honour
OP
14 Nov 2005
Up North
Don't feel bad m8. You were no#1 for a while ;).
Once we have enough entries I'll split the cards up into categories (not that it will help you much lol). 5xx, 4xx, 2xx and 6xxx, 5xxx, 4xxx but keep the top tens for the glory hunters?
Mebbe split the dual core GPUs from the single core?
16 Oct 2009
Essex
Top 10 is not necessary, top 3 should be more significant once you got 100+ entries. Keep the entire list atm, we'll see how far it goes :)
I'll see if I can bench at 1GHz on core in a minute ;)
Status
