http://www.droidforums.net/forum/droid-labs/74028-root-droid-1-regardless-os-version-139.html
See post #1382... same error as you reefoid and his solution is a new SD card.![]()
Hmmm people will already know how I feel about Clockwork and it's not unknown for its problems in the past. How old is your recovery version?
In CM7 how do you set the ringtone as a song on the phone memory? Its only giving me the stock options and no select file option.
Also why won't some of my apps download? Things like Flash Player and a couple of others start to download then just disappear. Very strange.
Apart from that CM7 is really nice and I prefer ADW to LauncherPro. Love the red rendering for night time.
I had the same problem with google maps, this was after installing g-apps by recovery, and also rinning S2E.
The solution was to clear the cache. Maps installed ok after that.
There's far too much crap involved with all his s-off, tables etc etc.... I'm so confused, I've been on leedroid 2.3c I think for ages now and I'm getting fed up with the poor battery life. Is there a decent rom etc... that I can install the old fashioned way? I've got AmonRA recovery installed.
I'm embarrassed to ask this but how do you remove a widget from the home screen?
Stuck two widget clocks on there I cant find a way to get rid of them. I'm using CM7 if that makes a difference.
Its not like the smaller icons where you can hold it and it vibrates then you can drag to the trash.
