TEGIWA have the best **** for the money , carbon airbox, and a toda copy header, that will cost you about £700.
Careful, copies are not guaranteed to be the best quality or fit
Have to say, the airbox is spot on..
Its not exactly the same engine and in factory trim most are dyno-ing (on the same dynos) with about 10bhp more due to better factory tune, lower VTEC engagment point without the drop in power prior to VTEC, shorter gear ratios and less drag compensate for the weight...in the real world it's down to which driver is faster. As for worse chassis I assume you mean suspension, yet on all indepent tests (except Top Gears test) the FN2 has pretty much the same cornering speed as the EP3![]()
Yes its heavier but it has a lot more kit, is safer and in my opinion better looking (especially with selected Mugen parts).
What about with manifold also and sports cat if a remap aint needed, say 200 cell cat?
I am a bit of a steady eddie 80% of the time truth be told.
Then just an RBC and any 2.5'' cat-back exhaust and then a tune on a k100 will have you making 245-250HP, and more fuel efficient than standard.
The cars feel awesome at this level, you will be giving 280HP+ cars a run for their money with the power/weight and gearing on the EP3.
K-100 supplied and tuned is £810, RBC kit can be had on ebay for about £250 ish, then just whatever exhaust you like the look/sound of.
Careful, copies are not guaranteed to be the best quality or fit![]()
IMO, the FN2 is gash, and I'd challenge you to try and keep up with me in my stock DC2 which has done 130k miles and on crap tyres on a track or even a B road point to point. You won't be able to. If I were in my CH1 you wouldn't be able to and you wouldn't be able to in the others either.
Let me know if your up for it, just to warn you my car is not stock but you still sound very confident that the almighty DC2 will beat a FN2 no matter how tuned a FN2 is. Yet the Mugen M20 FN2 is the fastest hot hatch of the current batch on most tracks (beats Focus RS, Megane R26.R).To sum up I agree a stock DC2 will beat a stock FN2 on a track when driven by drivers of equal talent, but when sat on the M25 I would rather have my air con. Also turning off VSA stops it coming on so resolves the LSD issue you mentioned, but I agree it is annoying everytime I get in the car I have to turn it off.
A friend has the one linked in the op but in black (same year) and it's a nice car but when VTEC kicks in it doesn't feel how I imagined it would feel, it didn't make me want to go "VTEC JUST KICKED IN YO!"
You can just about hear it but it's not as obvious as one with mods like you've mentioned and doesn't sound as nice as other VTEC engines either (Integra etc). There's definitely no kick, or if there was I didn't feel it![]()
As for the K20Z1 pushing out 10bhp more than a K20A2 in standard form as stated on P1, give me a break, they both put out the same power (well, 1 bhp in it). If they all put out 10bhp more, then honda would sell it as a 208bhp car. All engines are different, and some put out more than others.
Honda put in a weaker oil pump system as according to them "Brits don't check their oil" so the system is designed around that fact over performance also it has weaker con rods.
It isn't much of a kick, guessing you was expecting a turbo like feel that pulls you back at "warp" neck speeds![]()
I've driven a family member's Accord Type-R and that has a noticeable kick as VTEC comes on, the Civic was more muted which I wasn't expecting given the popularity of the meme and Civic combined!I was expecting a little more reallyI've driven a family member's Accord Type-R and that has a noticeable kick as VTEC comes on, the Civic was more muted which I wasn't expecting given the popularity of the meme and Civic combined!
