Brodit now supply a passive mount for the SF. Active mounts are supposedly in development.
http://www.brodit.com/?main=productinformation.jsp&anr=511235
sod that thenshe'd kill me if i flashed her phone now shes gone to bed and the same happend, why do they bother with such a flaw?
because its something the yhavent yet worked out how to fix, It will be at some point no doubt, it just takes time.
I just ordered 1 untill I get the Samsung Galaxy S2, just gotta decide on what ROM to flash it with
Got my Nillkin jelly case today and it fits just about perfectly, can even charge it without removing it![]()
I have that case too it's a great fit...
So i ask, would a custom rom improve performance massively?
Do you find your phone seamless and faultless with a custom rom?
thanks
Yup it's 3.0.0.6 just grab the zip, whack it on the sd card and install it from boot like you do with rom files.
Works perfectly fine as i did mine yesterday, using the same one you're using
http://android.modaco.com/content/z...clockworkmod-recovery-for-zte-blade-oled-tft/
Also it's non destructive, i also went from jj7 to flb g2 r10? anyway again non destructive just flashed it straight on top.
http://android.modaco.com/content/z...3154/rom-oled-tft-flb-froyo-g2-for-zte-blade/
I prefer flb, though the difference is marginal, i find flb less cluttered, jap jellyfish kinda forces certain bits onto your phone, whilst some are good like app2sd and adguard, others not so.
I wouldn't use cm7 atm, too many bugs and it's a battery killer.
