How much did this system cost? Around £3,000?
And the rest.
considering the vast majority of PC games will not scale very well above 1920x1200 (even if they did/do the low res textures will look even poorer
) it would have been better to buy a massive 60"+ HDTV @ 1080P for the immersion factor which would give you a better gaming experience...............Wow what an epic pointless waste of moneyconsidering the vast majority of PC games will not scale very well above 1920x1200 (even if they did/do the low res textures will look even poorer
Seeing this is a gem find for me!!
I'm in the same situation with 3 30" screens and not being able to find a GPU to run them at the res and detail levels that I wanted!
So let me get this right, your using 2 or 3 3Gb cards for this setup? Reason I ask is that I have the landscape version of this and I want to make sure I get the best I can possible to make sure that I dont have to spend out twice on something.
I've just sold both of my 5970's and I really want to make sure I get the right GPU next. Sadly I have to buy a new PSU as my current one blew up on me yesterday, so I need to get two for each i7 rig.
Then when I've got some spare cash the GPU's will be bought!!
Thank you so much Thug for posting the details and thread up![]()
Thats the plan
But having to maybe buy 6 of them, its a little hard to swallow but we'll see![]()
TRI-SLI worked pretty good but at this resolution in games I was still GPU limited. With 4-way, in a lot of games I still max out all 4 GPUs.
lol 1080p. Why would I want to play at such a tiny low resolution? Computer games scale incredibly well at high resolution.
Here is a picture of a pixel perfect 1080p movie on my desktop just to give you a comparison:
Aw, its so cute. Anyone who buys a 1080P TV for computer use is clueless to begin with so I am not surprised.
I went with the Palit cards. Palit/Gainward (same cards just different air coolers) are the only ones that make 3GB 580s. They are hard to find. Been out of stock in the US for a long time. I had to order one with OK UK and it appears they are out of stock on both version now too.
I've just got another two on the way for a replacement and for another rig
Running Dirt 2 at anything more than medium just wouldnt work because of the sheer amount of detail on the screen, I went from 55fps to 5fps!! Mind you that was with a single card also, when I tried another 5970, it slowed it down!!
Tbh for me that looks awful. I'd hate that and wouldn't get it, even if I did have the money.
Most computer games don't scale that well, especially when you start hitting higher resolutions that the raw textures are at.
BTW just so you know, adding extra cards does not add extra memory, each card must hold a duplicate copy of the data in the first.
3x2GB cards in crossfire would be 2GB total.
I think he has got a 990x overclocked...![]()
