OLED is nicer... but not a deal breaker. Worth paying £10 more or so IMO (a few pop up on ebay very regularly). I specifically went for an OLED when I got my girlfriend one and the screen is awesome for such a cheap phone.
			Doesn't make any actual different to the usability of the phone though, just the quality of the picture? I can still put the custom roms on both?
I put a custom ROM on my phone last night, the Japanese Jellyfish 2.2 one that orangesanfrancisco.co.uk recommend. It seems pretty good so far, certainly a little snappier than the orange original and with none of the apps that I'll never need clogging up the app list.
I have wifi off gps off 3g data off so its just 2g with no data and even with no calls after 24 hours its less than halfway
To Root:
* Download the ClockWork Recovery Mod. (Download)
* Turn off your phone and take out the battery. Unplug the phone from the PC / charger.
* Replace the battery and turn the phone back on with 'volume up' held. The device will stay at the 'green android' screen.
On mine I'm sure I had to keep volume down pressed.
I used the www.orangesanfrancisco.co.uk site and everything was straightforward on a new B10 build number.
Well, I've spent approaching eight hours now trying to fix my unresponsive touchscreen and I'm giving up. I've been posting at modaco.com but apparently the only thing I could try at this point is a 'total phone transfer'. And in order to do that, I need to network-unlock the phone first, which I cannot do if the touchscreen doesn't work.
So, I appear to have bricked this phone by doing something that was supposedly completely safe and reversible. If anyone has any suggestions or has had any touchscreen issues that they resolved I would welcome any advice you might have. Right now all I can think of doing is trying to return it to the retailer and hoping that they do not notice I have messed with it.
edit: sorry for double post, I didn't realise I was the most recent poster itt
My touchscreen went unresponsive after installing Japanese Jellyfish!
so I installed the flb froyo blade r10 rom which seems to be a massive improvement as far as responsiveness goes.
I've been advised to try X and Y other custom ROMs, but reverting the phone to stock overwrote ClockworkMod, and the newer SF models don't have fastboot, so I can no longer flash to a different ROM. The phone seems to be bricked for good. I'm going to take it back to the retailer and try to get a new one, wish me luck![]()
Good luck!
Hope you get it sorted
