- 10 Sep 2010
- Cornwall, England
Some SS's from the event viewer.
Thanks for taking the time to do that
I take it thats a driver related problem? Driver crash perhaps?
have you tried older gpu drivers? try underclocking your mem on your gpu's by 20mhz, some say this works, they also say raising pci freq helps
Are you sure its not the cpu overheating? bad contact with the waterblock, or older block(or newer one) clogged with bits of gunk, pump working at incorrect voltage, something along those lines.
Did you try without the fan controller, its not hugely likely but its possible for a fan to cause some issues aswell so could try turning half off, then the other half.
Some setting you've overclocked, cpu overheat protection set too low, or ran rpm safety which is auto shutting down without detecting cpu fan, that kind of thing.
Nvidia driver crash, despite the love of bashing Nvidia, is likely down to an unstable system vs bad driver.
They do make the odd bad unstable driver, everyone does, but because of the usage, crashing more in 3d, and also just because the gpu is one of the biggest and most complex drivers, its the most prone to failing in an unstable system.
99% of AMD "driver has recovered" or the total crash version, and Nvidia driver crashes are down to a system thats just not stable. Frequently caused on this forum by someone having a X specced rig which is stable at whatever overclock, then they go from a 285gtx to a 480gtx, and suddenly its Nvidia driver crashes all over and they suspect bad cards/drivers, when normally its just that extra power means that for example 3.7Ghz overclock, is now only stable at 3.65Ghz, because the CPU is being pushed more, the gpu is pushing hard, the psu is being pushed harder and is a little hotter and the rails have gone down marginally.
I'd try again with a minimal system, make sure all hardware monitoring type things are disabled in bios, check the bios temp readings, make sure the cpu isn't getting too hot. Increase voltage, marginally, on the cpu, memory up 0.1v over whatever its default is, not bios default. Just the hdd, as few fans as possible, off mobo headers or molex's, disconnect the fan controller, one gpu, check with the PSU which rails everything is on, keep both pci-e connectors for one gpu on the same rail, also have the memory at 2t rather than 1t.
You could always, depending on whats around you, take the computer in to a shop ask them to have a look for you.
Well I would say graphics cards don't have enough voltage for their factory overclock
Also what sort of tight duck mate let's u only test for 10 mins
Check your socket out let voltage are u using a multiple plug exstender?
