Rome was not built in one day !!
7 Nov 2002
pantyhose factory
So I have finally got around to opening my parcels and unpacked my Sandybrdigebuild goodness. This build will likely take me a while as I have not built a new machine for around 5 years and with my job I get very little time at home. So I thought I;d keep a log of my building progress.
it starts here with the gear I unpacked from the boxes
As it slowly comes to life I will post mroe photos and commentary
Nice looking setup. You might want to move your build log into the cases 'Project Log' section though. I am interested to watch this build too due to you using a CM-690. When I bought my CM-690 they were only just out I believe and I didnt expect how good they would be generally. Glad I bought mine now. Also, what is that Modern-V thing? Is it a fan controller?
Step 1 Installing the PSU
I didn't know if I should have it with fan out or fan in !!
Clearance at the bottom of the case seems good and it going to be stting on my desk where blasts of cold air come in from the window so i opted for fan out.
That's what I would do.
I will also be follwing this build log as I'm interested in the CM 690 II. You have a very nice selection of parts, will make a great build.
Yes its the advanced version.
Got the DVD and the Fan controller in now
Now I remember why is hould have been patient and waited for the xfx modular PSU's to come into stock !!
theres more cables than the national grid !!
I have a distinct feeling that beer is about to stop play :D, so probaly carry on tomorriow as I don't fancy installing the motherboard under the influence of stella !!!
Forgot to add so far I am impressed with the CM690II. the cable management holes seem to b in just the right places and even with my saute pan sized hands there seems to be ample sapce inside
But the beer away and carry on with the build, the beer will keep for another day!:D
Nice to know your're impressed with the case. Whats the build quality like?
*edit*
Is there enough room for all those cables. I think I will go modular.
*edit*
The build quality is really good, the finishing on both exterior and interior is top notch. I think once I get the mobo in there and star running pwer leads to the GFX, MoBo, DVD, Fan controller, HDD that the cables that are surplus should fit niceley in the cavity betwwen the back of the chasis and where the side panel fits. Modular would have deffinately been a better cable managment strategy though
The only thing I am having trouble figuring out is which way the 3 pre installed fans will blow. I am assuming here that the fron one is intake, the rear on is exhaust, so I guess that leaves the top one as exhaust also ?
Yes you are right. Front is the intake, and rear/top exhaust.
