Did you buy it from Apple?Well, mine turned up just now. Will have to go back or go to an Apple store or something though as it has awful backlight bleed. Not happy.
No, but an Apple store will be the fastest way or getting it sorted I expect.Did you buy it from Apple?
Will do in a bit. It's syncing at the moment.Any chance of a picture, just so I can compare it to the other ones I've seen.
Heard of a few suffering from BLB.
so happy!Aye if mine suffers from BLB I'm keeping it for a couple of weeks until the fuss dies down and they can replace within a couple of days, not weeks/months.
I expect I will do the same. Will do some comparison shots vs my iPad1 to illustrate the bleed in a bit.
That would be much appreciated from this end as I can then compare and work out how annoyed I'm going to be when mine arrives
Did the first gen suffer from this problem? I thought it was the same screen? Maybe a bad 1st batch, you'd think they'd quality control a little better when needing to maintain dominance in the tablet market in 2011.
