Well there is no reason you can't spray it (that I can see anyway), it will just require some practice so that you don't end up with paint dribbles etc.
Any idea on what paint i should use?
How much did it cost for most of you to liquid cool a tj07 with a 240&480?
I just need a rough idea.
WOW!
im pretty scared i may get a bit OCD and end up spending £1000s!
What sort of wattage should i be looking at for the fan controller as i want a touchscreen just for the wow factor.
Have you git any of the x58 stuff that you plan to sell by any chance?
If you're looking for a good, but flashy fan controller, you need to look at the Lamptron Touch. 30W per channel, 6 channels, good touch screen. Much better than the Sentry which will struggle if you put even 'normal' high RPM fans on... (3W per channel or something?)
Forget the fluid and get some mayhems pure water and a silver coil.
The tubing cutter you have is rubbish don't bother, buy some decent scissors.
The HDD cooler isn't worth it save yourself some money, it wont make it less noisy.
Anyone?
