***** The Crysis 2 Thread *****
Just noticed I had acquired the Drunk & Disorderly tag in multiplayer :
" Finishing in the bottom 3 of 3 consecutive rounds after 11.30pm at night "
Go me :)
i got that one. Played whilst i was ****ed the other night. in one game i was 2 for 16!!
gonna give it a go now. try the TFU server first i think
Just had a go at this multiplayer for the first time, enjoyed it for a quick fix, loved the way someone just appeared in front of you and mowed you down :)
Liked the powerjump effect as well, makes you quite mobile around the maps at times.
Single player is a bit "simple" but worth a play just to see how the story pans out..
tried it again online.
There is no point in playing it at the moment. there were at least 2 cheaters in the last game i played
watch their killcams, and they are not even looking at you or holding a weapon, it's ridiculous, i mean, what's the point!!
My aiming is so bad though, that even when i do get a decent game, it doesn't make much difference. LOL
one game i was, i think, 4 for 6 with 6 assists!!
i'll try it again when i hear it's been fixed:)
i went back on, and they kicked the obvious cheaters, and it was a really good game.
it's a shame that they are ruining it really!!
Although the automatic shotgun is annoying
Really enjoying the later levels of the SP the graphics are incredible on the night time levels the lighting is fanstastic and i'm sure the AI of the aliens seems to get better in the later maps, the in game cut scenes are great too, looing forward to playing through it again when its patched up and modded
It's good fun although the hit detection is shocking at times.
And that's not a whine because I die frequently :p You can be aiming at someone's crotch / chest , take them out & the killcam will show a headshot.
I've seen that in BFBC2 though :confused:
Get shot, kill cam and the guy is in some building crouching down not even near my position
In BC2, it's not a real killcam though is it? don't you see the killer after he has killed you?
Moody, you got a final kill in one game, which was a double kill, and on the killcam, it only showed you fire 2 bullets and they didn't even hit them!!!!!;)
I was bottom in 2 games in a row with figures like 2for10 and 4for11, then they kicked that hacker(Chevantes or something?) and i came back and was top for the next 2! He killed me 6 times on one skyline game, and he was running ridiculously fast and not even firing at people.
BTW Moody, we ran past eachother in a corridor, both uncloaked at the same time and started to mele for about 5 seconds, i have no idea how i got you there:p
BTW, i'm about 6 hours in to SP now, and it is definitely improving, i would say
Cloakes... Hides behind a large object and Decloakes
" HE'S DECLOAKED "
What?
Cloakes... Goes into the sewer
" HE'S IN THE SEWER "
*Uh right*
Found this on a forum for anyone having the flickering issue with CF/SLI
"Seems the problem may not be with ATI or Nvidia drivers but with the Crysis 2 ver 1.1 auto update. Open Crysis 2 root file, open backup folder copy Crysis2.exe.bak and rename as Crysis2.exe. Open Bin32 folder (if you are using 64bit OS) and Replace Crysis2.exe file with the one you have just renamed from the backup folder. Seems it works perfectly - running at 90fps no flickering"
Changing the exe file to rift worked for incidentally.
Apologies if this is a repost :)
" HE'S DECLOAKED "
What?
*Uh right*
I think that is part of the plot?
Just saved at that bit, in SP before and exactly the same happened for me. :)
Games starting to annoy me:mad:
checkpoint placement is crap,i keep getting stuck behind walls because of the crap cover system.and the ai is well:/ while some will do stupid things or see me from a far while cloaked,the worst is them seeing me through walls
and after a few steps back im still getting shot at through a wall
