Maybe in the banner put where it is and what it is about?
Looks good, I would join if i lived in Kilmarnock and liked judo.
I've also done a "rank structure" so when a user reaches a certain amount of posts, he/she receives a belt. It's something like
50 posts = white belt
500 posts = black
Think this is a good idea?
Sounds good!
@Greenlizard, lets do it!
In forum management make a new forum.
Type: category
No parent.
set the registered users to standard access
Then make another forum (or edit an existing one).
Type:forum
Parent: the category you just made.
Then you need to set permissions so everyone can see it:
Admin control panel>Permissions>Groups forum permissions.
Set the registered users to be able to see and post in it:
Registered users>Standard access
Would be better if it automatically returned you to your post![]()
Is it possible to sent PMs i can't seem to find out how.
http://www.kilmarnockjudo.com/forum/viewforum.php?f=15
Thread seemed to work
Also i got the PM but could not find anything to reply :|
Colour scheme is abit dodgy.
Muddy grey text on muddy grey is not that readable.
Unless i am blind.
First rule of text colour in my opinion is to not have two of the same colours. The grey background with grey text makes it hard to read. There must be a section in the CSS for the theme to change the text colour?
