Need opinions on website?
Maybe in the banner put where it is and what it is about?
Looks good, I would join if i lived in Kilmarnock and liked judo.
I've also done a "rank structure" so when a user reaches a certain amount of posts, he/she receives a belt. It's something like
50 posts = white belt
500 posts = black
Think this is a good idea?
Sounds good! :)
@Greenlizard, lets do it!
Joking aside. I think I may have screwed up the permissions. So if you could register and just try and tinker around with some things... make everything is A-ok... that would be brilliant.
I trust all of you fellow overclockers too not steal my site from me :p
In forum management make a new forum.
Type: category
No parent.
set the registered users to standard access
Then make another forum (or edit an existing one).
Type:forum
Parent: the category you just made.
Then you need to set permissions so everyone can see it:
Admin control panel>Permissions>Groups forum permissions.
Set the registered users to be able to see and post in it:
Registered users>Standard access
I think that's the way it's already setup to be honest. Is it not?
Would be better if it automatically returned you to your post :)
Is it possible to sent PMs i can't seem to find out how.
You should be able to send PM's no problem. I'll try sending you one.
Could you also try and create a topic within a category please, just to see if that works ok for you?
Colour scheme is abit dodgy.
Muddy grey text on muddy grey is not that readable.
Get an IPS panel :p
Just kidding, it's a lot better than the default theme from phpbb. It's very readable for me, so I think i'll stick with it for now.
If there was a way to change it too white text that anyone knows of. I agree it would be better.
Unless i am blind.
First rule of text colour in my opinion is to not have two of the same colours. The grey background with grey text makes it hard to read. There must be a section in the CSS for the theme to change the text colour?
I'll have a look for the css file... should be somewhere, any idea what I should be looking for when I get it?
P.S. I love Kawasaki bikes. GORGEOUS!
