Although you should remove the RMA bit:
I just had a webnote update from overclockers.
Doesn't mean that people won't try to RMA them.
This would be a good option for sure as when dust develops you could wipe 99% of it away.
Shall forward thread to Hazro and hopefully we shall get more input from them.
Hey Gibbo what percentage of the Hazro HZ27WC are seeing these problems
has the Hazro HZ27WA had the same amount of problems
None yet and they are still selling rather well.
But remember guys a lot of users buying these will probably never notice the dust on a monitor like this, because remember even a dead pixel on a monitor with this resolution 2560x1440 is incredibly small and dust particles are smaller again, resulting most users won't even notice such anomolies. Most of our customers will get them and just be amazed by the image quality for the price.
+1I think if Hazro could fix the dust issue like Apple managed to, then these monitors would be simply unbeatable in this price range.
	I wanted to add to the list of problem hazro screens. I received my HZ27WC today and have found the following:
1. Dead pixels. Mine is particularly bad with a 3mm line and round cluster of them. Total dead pixels is enough for RMA fortunately.
2. Dust. Many small particles all over the inside of the screen. I find it hard to believe these were put together in a controlled 'clean room'.
3. Poor build quality. Badly fitting glass, humps in the plastic on the top of the monitor where the halves join together.
The image quality appears to be very high, and i would consider the screen a good deal if issues 1 & 2 were fixed. However, I don't believe these problems are acceptable in this price range, and urge Hazro to re-evaluate their quality control measures.
I am sending mine back for a refund and have purchased a U2711h instead.
thats pretty rude isn't it? they didn't "bung" me anything for the review and i have only ever reported honestly about the screens i've reviewed.
Yes that is rude. You did a good job mate and we all know it, don't let him troll you. I'm very happy with my screen, sad to see so many people have those dust problems.
Does your screen suffer from the yellow tint problem?
http://forums.macrumors.com/showthread.php?t=824940
i do using the pixel test software on a totally green background. Under all other circumstances it doesn't show.
