Well a good day and a bad day.
Got a lot done on the case, but have had to change my plans a bit.
1st off a few pics of the progress (the good bit), bad bit at the end.
Decided to go with the stock kit in the end. I can always change it later if I want a change of scenery.
I always PTFE my fittings. PTFE is an active barrier, and the O ring is a passive barrier, but no reason not to have both.
Silverstone air penetrators on the Rad. and barbs fitted
Barbs fitted to the res
The i7 ready for....
The Rasa
Bit of a blob
Thought it all looked so pretty It deserved some nice shots.
Ok now the not so good bit. I was originally intending to have the Silverstones inside the case under the rad pushing air up and out through it, assisted by the fans that come with the case having a bit of a pull from the outside of the rad.
However....
There aint enough room inside to have fans pushing up and uot.
So a couple of options.
1 Just the silverstones as pull on the rad (they don't work at their best as extracts)
2 the silversones as push from the top down through the rad. this of course would be great as it would be cool air from outside the case being pushed over the rad, only problem is it's then entering the top of the case area. perhaps the rear case fan would be enough to remove the warm air, although I'm a bit worried about general air flow through if I do this.
3 find another fan to use as extract, either the fans that come with it or the orange Bitfenix I have
So what do you think guys?
The Rasa
Bit of a blob
However....
. RS240 needs reasonably good air flow too.
