 - 10 Apr 2006
 - North West
What do you guys use as snow foam in a pressure washer?
			How would you go about cleaning headlights? Normal washing doesn't seem to get rid of the weird yellow shade. Ruins the car.
Thanks.
Thanks.
Thanks for the tip for dealing with the hard-ass southern water Gibbo, I used a chamois rather than a towel but it worked a treat:
 and it seems to be leaving VERY small specs of what i can only describe as pollen? they come off with the finger nail, but not just normal washing.. is there anything i can use to get this crap off?Don't use a sponge, use a lambs wool wash mit. Secondly, use clay to remove surface contaminants.just a couple of quick q's about the car..
i've noticed after cleaning it with a sponge and some wash etc.. it seems to leave very very fine hairline scratches on the paint, is this normal? (only viewable in certain light conditions i.e the sun)
also, i have to park next to a cherry blossom treeand it seems to be leaving VERY small specs of what i can only describe as pollen? they come off with the finger nail, but not just normal washing.. is there anything i can use to get this crap off?
ok. notedis there anyway to remove the hairline scratches? i guess i'll have to polish it now >_<
Bit the bullet and bought a machine polisher. Might post some pictures near the end of next week if I get it finished.
Buying myself a DA next week to give my 182 a going over (black gold) as it's a total 'swirl bus' at the moment!
First time with a machine polisher of any sort DA/rotary and fairly confident I'll do a decent job and won't cause any damage which I read is almost impossible with a DA providing you're not a total tool.
