How fast is your Photoshop ?
10 Apr 2011
London
Work PC - 29.7 seconds (CS2 Intel core 2 duo 1.6ghz)
Laptop - 25 secs (MBP Dual Core 2.4ghz)
Home PC to come later!
3 Feb 2008
58 seconds on my work PC :(, a P4 3.2 with 1GB of Ram running windows 7! and they expect me to work on this thing?!!!!
Can't wait to try it later on my i5!
What on earth work do you do involving Photoshop and a 3.2ghz P4 with 1gb of ram? :confused:
Btw, not sure if it's been mentioned but if you're having trouble timing your efforts, Photoshop does actually have a build in timer system. At the bottom left of the open document window you will see a small grey bar with a black right arrow next to it. Clicking it will bring up a small list of options, one of which will be 'Timing'. Select it, then run radial blur. It will tell you how fast the last thing you did in Photoshop was executed :)
27 Nov 2004
North Beds
CS3
Vista 64
Q6600 @ 3.6ghz
400mhz FSB
4-4-4-12 Corsair xms2 pc6400, all running sync
7.71 seconds with slow reactions :D
Intel Core i5-2500K 3.30GHz
Asus P8P67 LE Intel P67 (Socket 1155) DDR3 Motherboard
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
and a samsung ssd are gonna be replacing the q6600 this week :D Get the clock speed up to 4+ghz and see if i can dip below 5s.
3 Feb 2008
Only 4GB? Cmon man, strap on a pair and get 16 in there! :p
15 Apr 2011
Stafford
5.6 seconds
Intel Core i7 950 @ 3.9GHz
ASUS P6X58D-E
Kingston HyperX 6GB (3x2GB) DDR3 12800C8 1600MHz Triple Channel
OCZ 120GB Vertex 2E SSD
CS5
Windows 7 x64
14 Apr 2011
Essex United Kingdom
Many people out there still complain that Photoshop CS and CS2 are too slow at applying adjustments on large images, some say 7 is faster all round - maybe this is true, maybe CS and CS2 favour newer processors who knows!
Here's a small test to try (unashamed to steal this from a hardware forum :p)
Download This Photo and follow the below steps after loading it in your Photoshop version.
Have a stopwatch handy to see how long it takes :)
I got 37secs using a x2 4200+ 2.2ghz/core on CS2 (2gb ram)
Answer to that is very fast :D
