- 7 Dec 2010
How about on my 4770? the gpu die is only about 12mm sqare... Be hard to do an X on there, it would just be covered lol
Ratio for die size
Take one of both A and B and place glossy sides to the IHS and sink with the "Frosted" sides facing each other.
One is the donor and the other is the "Print"
Mount your sink as you normally would with out paste.
Dismount sink remove paper - throw away blank piece
Sensorproducts.com has a pressure interpretation sheet that you can use as a general guideline.
You have to return the print to me which I send to sensor products for analysis. - sorry I forgot to leave instructions for a return mail envelope with my mailing person.
Raw image will tell you a lot out of the gate and you can compare to the review and if you post the i9mage I can give you some feedback on it till you get the analysis.
Can be used to improve contact and performance -progressive lapping etc.
Thanks
So take 1 paper from both A and B with the glossy sides facing the cpu IHS and heatsink base with the rough sides facing each other. Does it matter if A paper goes on top of B paper or vice versa?
Ratio for die size
Alternatively "X" pattern works great - If it is not spreading it is most likely a pressure issue.
I would re-torque the screws periodically over a few days to take up slack as the compound thins.
. The paper pic is almost actual real size but slightly bigger. Basically this is as you are reading the cpu info on the IHS. So it is either top-bottom or bottom to top pattern (or vertical line pattern). As you follow the central contact line to each end you meet the IFX-14 heatpipes.
My results using Diamond:
Old paste - Mx-3 - 1 month old
Idle: 46
Load:
IC Diamond - 5 minutes old
Idle: 46
Load:
Will update in a week to see if it cures. Then will switch to Perihelion
First of all here are is the spread pattern of IC Diamond which wasn't previously available after the testing has been conducted as I never took off the heatsink after carrying out the tests on IC Diamond. The pics are clickable
IC DIAMOND spread pattern after tests completion
As seen IC Diamond spreads out much better than both IC Perihelion and MX-4 See Post 291 for more details). It is a nice smooth layer. However I found that IC Diamond has slightly 'dried up' just like in the case of MX-4 whereas IC Perihelion seems to be slightly wet even after one week application . Is it due to viscosity?
IC DIAMOND spread pattern on IFX-14 base
However for each thermal compound I tested The bulk of thermal compound seemed to be attached to IFX-14 base as seen in the 2nd pic. So I think what we are seeing on cpu IHS is the very bottom layer of thermal compound which understandably is more drier as it is closest to cpu cores.
However now for the main part of this post:
Lol![]()
(Apology. Digital Camera is rubbish)
I knew it!!. The Thermalright IFX-14 base is convex. The paper pic is almost actual real size but slightly bigger. Basically this is as you are reading the cpu info on the IHS. So it is either top-bottom or bottom to top pattern (or vertical line pattern). As you follow the central contact line to each end you meet the IFX-14 heatpipes.
I am disappointed with manufacturer base machining or as stated before this is meant to be their design philosophy. However in this case it seems pressure/contact decreases in the centre. Judging by the pic only 25-30% of the contact area is actually utilised.
Then again it could be Q6600 IHS itself which could be concave.
Now I know why I seem to get higher temps as I push for further overclocks. Its a brilliant cooler but with poor base.
Hmm I can't reach conclusion other than to resort to lapping.
What do you reckon IC Diamond and fellow ocukers?![]()
i spread a thin layer across the cpu....never read a thread about applying the thermal compound before but by the looks im doin it wrong...am i right in saying you just put a pea sized blob on the center of the cpu if using the diamond ...let me know thanks.
WingZero
Interesting stuff. Is it the HS or the CPU? I am assuming this paper is between the two?
In this situation I would imagine you will be getting the full benefit of a good paste because your totally relying on the thermal conductivity because of the lack of contact. Lapping should help there.
The "I" pattern is interesting to me as it shows the bulk of the load carried on the top & bottom edges as in the ICD vs AS5 review which would seem to be a typical pattern with just a couple of samples.
Makes me wonder whether with the TR sinks with exceptional pressure in such a small area is deflecting the IHS on that axis and causing the top and bottom edge contact?
Might be interesting to draw a contour map + with a straight edge on both IHS and sink.
In the ICD vs AS5 tests lapping not only produced a compound/contact improvement but overall improvement was 6 C nontrivial and and would seem worth the effort.
From my understanding the water block manufacturers bend their blocks to a tight tolerance. - however on a couple of forums some have raised the possibility that the bend on many of these heat pipe heat sinks the bow or bend is due to heat warping on when soldering the HP's to the base. Some thing to think about
With the TR high pressure mounting system it seems a waste to not utilize increased contact area for an edge in performance.
. Or may be they do it intentionally as part of their design philosophy. But I agree it is a waste with all the remaining potential contact area not being utilised.
) as a result of lapping? This can also be seen in the unlapped vs lapped pic you have quoted where the red colour in lapped pic is slightly lighter?
May be there is a market for these contacts kits?
I know I have used and lapped CPU's in the past and had minimal gains. Knowing you have a poor spreader or HS base would allow you to sort any heat problems out.
Sounds like a winner to me?
WingZero30 - One thing with lapping is that by doing so, wouldn't it decrease the overall pressure between heatsink Base and CPU IHS to a certain degree as Force applied by heatsink mounting system will spread out onto more CPU IHS surface area (Pressure = Force/Area ) as a result of lapping? This can also be seen in the unlapped vs lapped pic you have quoted where the red colour in lapped pic is slightly lighter?
I have seen on some forums including in this one where some people placed 1 or 2 washers underneath their heatsink mounting systems after lapping.
