I'd change the partitions as there is 80mb that isnt used.
How do I get the list of partitions I can use? I remember seeing them the first time around when I first did it, but can't remember where.
Cheers
Cheers
Posted info in this thread before but seems like the below is the easy way of doing the upgrade
http://android.modaco.com/content/zte-blade-roms-rom-customisation/337798/gen1-to-gen2-tpt-upgrade/
EDIT IF YOU ARE ALREADY GEN2 ID USE THE WINDOWS TOOL ON MODACO
I am already on Gen2 running CM7, I might be getting a little confused - I just couldn't remember what partition I used the first time around and I thought I might have been able to freeup some space.
Cheers
All info you need is:
http://android.modaco.com/content/z...281/how-to-upgrade-gen1-to-gen2-windows-only/
Read the link but basic info from that is:
Download Stock FTM recovery from http://www.mediafire.com/?kx76glmuxym6adp
Use ROM manager to install it.
Download the GEN2 Update http://www.mediafire.com/?dl9wettauw6vk7h - Install the USB drivers.
CODE
gen2_136mb_system_no_oem_15mb_cache
/dev/block/mtdblock4 15.0M /cache
/dev/block/mtdblock5 136.0M /system
/dev/block/mtdblock6 289.88M /data
Then download your GEN2 Rom - I'm using the CM7 TEMP rom http://kan.gd/c4s
The process android.process.acore has stopped unexpectedly. Please try again.
No idea what's up with my phone.
It seems to have reverted to the ROM I was using a couple of weeks ago, and whenever I click something it pops up with:
Code:The process android.process.acore has stopped unexpectedly. Please try again.
Anyone know how to fix this?
Cleared the cache etc?
Yep. The error message appeared yesterday so I restarted the phone, and it returned with the old wallpaper etc. Although it appears it is still running swedish spring and not my previous ROM.
Have done now, just hope it stays this way.
I wasn't able to backup my messages as I couldn't open the message application, I've got a feeling I've missed some this morning too![]()
The new CM7 also drained my battery totally over night - Anyone else had this issue?
Thinking of bagging one of these, sorry if it's been answered before but are they all tft screens now or have they started oleds again? or does it even matter, just ive heard oled is better for battery?
my SF running SS still cuts the wireless off after a certain period even when its set to never.....
Any ideas.??
got TFT my self.. really nothing wrong with it.. can't see this as a reason not to get it..![]()
