Why have and iMac when you can........
15 Dec 2008
London
You are not comparing "apples with apples" excuse the pun.You are comparing i3-i5 imacs with i7 macbook pros.
Wheres the macbook pro that beats my 2.93 Ghz i7 imac??
If you have a pre-2011 iMac then the *current* 2011 i7 MBP is faster as far as I know.
The newer SB based iMacs should be a bit quicker though.
18 Mar 2010
The screen is surely much nicer on an iMac?
Particularly now you have smartphones for web browsing, emailing etc, the portability of laptops is less necessary.
Permabanned
10 Apr 2010
Ok i stand corrected,but its still new spec vs old spec.What are the new SB iMacs doing?
Doesn't appear to be any geekbench scores up for any 2011 iMacs yet. But they'll be a significant boost over the Lynnfield chips and any dual core clarkdales in the lower spec'd iMacs.
15 Dec 2008
London
Depends on what you do for a living and how you use your machines really doesn't it? For me, having the ability to run my demo suite of 6 or 7 servers *in portable form* is invaluable. The stuff I work on is incredibly hard to demo/investigate remotely due to real time components (voice/video).
