Check out any of the Dell Inspirons over £400.
OMG!
http://www.dell.com/uk/p/inspiron-17r/pd
At that price for the specs I seriously want one!
Wow, i might just be beat.
Though i am somewhat mystified by the ambiguous 'Graphics - HD Graphics' next to the graphics chipset. Lets do a bit of digging. Oh yes, here we are:
Intel HD Graphics
The Macbook has an integrated graphics solution from nvidia, miles better than the Intel chipset and therefore: not a valid comparison
Try again.
+£120 on top of the £49 for the 1Tb, so £82 more.
I'll just enjoy a multitouch trackpad that no Windows machine can compare with.![]()
So the XPS 15 that's £200 cheaper? sporting an Nvidia graphics chip better than the Macbook one? Has more memory, and a bigger drive? and its an I5?
What you say to that one.
It tells me that the consumer doesn't value the Dell brand as highly as the Apple brandSo the XPS 15 that's £200 cheaper? sporting an Nvidia graphics chip better than the Macbook one? Has more memory, and a bigger drive? and its an I5?
I don't mind who slings what but trackpads are created by the devil himself.![]()
I'd rather have a Razer or Logitech mouse thanks.
You should try an Apple one then. It's actually big enough to fit a few fingers on.![]()
I've had a shot of a standard macbook, hated it.
I've yet to try macbook pro though. I'll come back here and announce my hatred yet again probably.![]()
Just looking at overclockers hard drive list it would most likely be the one around the £80 mark as the hard drives over £80 are Sata 3, Sata 3 in a x58 machine is a bit of a waste. Equally sata 3 on a mechanical hard drive is still a waste, but I doubt they would use Sata 3 as they would mention it.
Here
I would say take the two of them side by side..boot them, open Ai in each and open a file to size to billboard size and see what happens, have seen this first hand...was embarressing to say the least.
What ive come to discover is that the sum of the work each one can do has little to do with all out spec TBH.
I always thought that Macs were easier to use than PCs, and more stable, but when I first used one I couldnt find the power button, took me a while to figure out to save to USB, and the thing froze up and crashed when I simply pulled my USB stick out after the file had finished copying.
Meh, PCs are more stable and easier to use.
But also, Traktor DJ, As great as it is on both formats, I've seen its struggling point on Mac. Loading a 300GB Mp3\CDG library. And then trying to do a search afterwards, The Mac really does struggle, crawl, it locks up as it cant handle common terms. Like the, and, etc.
The same software on PC. No problems.
