Man of Honour
 - 13 Nov 2009
 - Northampton
Its a Z68 UD4 and its sat at my desk![]()
Thanks for clearing that up Andrew, I think I'll stop pestering you now.
Post #28 updated with 3DMark06
FAO Andrew/ whoever is keeping the leaderboards up to date..... the % OC numbers are miles wrongI think you're adding 100% too much to each score?
Updated with 3dmark!
What happens if two people get the same result, either in 3dmark or the same % overclock? Do they both get the points, or is it the first person to get it?
http://forums.overclockers.co.uk/showpost.php?p=19107133&postcount=82
That's all I've got for now. Don't think I'm going to be able to beat those overclock scores![]()
I'm not going to be able to either, I might have another shot and try for another 100mhz or so, I'm just worried about too much voltage as I've already killed a mobo doing it, the underclock and 3d mark are where the amd systems will make up the points.
I'll let you all into my underclock secret when the comp is over.
You've got the underclock, 1Day's got the overclock, you're both going to probably win your 3Dmark section, only difference is how you do in the other over/underclock competition.
Edit: Found a 4x multi and shaved another 200Mhz off my underclock XD
And there was me thinking I'd bagged an easy win
