hi,does the pitch have front/rear lockout ?
None of the Pitch's to date have front lockout however both the 2011 models have rear lockout/propedal. On the 2009 and 2010 versions only the Pro had lockout/propedal
Having now ridden my Rockrider for a couple of days, it's definitely starting to grow on me. The frame size issue is pretty much moot now too. Looking forward to getting a few extra things like the pedals so I can really throw the thing around.
I do a lot of walking and sport (running, football, gym) when I can, but I'm finding cycling quite tiring! Definitely exercising leg muscles I haven't 'used' in some time. Very much looking forward to some long bike-rides. Just need to get those padded shorts. Can anyone recommend any padded shorts?
ah i thought lock out on rear was a given for climbing ,i dont know never riden fs before. how does it handle climbs ? with a fs do you really lose a load of energy too the suspension ?
Hi folks, has anyone had issues fitting a Blackspire stinger using ISCG mounts?
I have both M5 and M6 countersunk bolts (got the stinger on ebay with no fittings) The problem is, the M5 bolts are too small and the M6 seem to big?
I checked out the guide on the Blackspire site and it shows the bolt as M6. Maybe I'm just meant to use M6 but jesus it's tight!
Bike is an On One 456 Summer Season
They are too big for the ISCG tabs on the frame. They sit nice and flush on the stinger
*kidding*ah i thought lock out on rear was a given for climbing ,i dont know never riden fs before. how does it handle climbs ? with a fs do you really lose a load of energy too the suspension ?
There deifinitly supposed to be M6.
Official document here by the way.
http://www.iscg.org/INTL_STD_MTG_LOCATIONS.pdf
Its the original design though but bolt sizes didnt change to the 05 spec.
